Converting from Carb to TPI???
Old May 14, 2007 | 03:20 PM
camaro87-alex's Avatar
Car: 1987 Chevrolet Camaro SC
I know this thread has been asked a lot before but I just have to make a new thread...
I have a 87 305 with a Computer controlled carb on it...I Was thinking of converting in to TPI if it is not tooo expensive...
I have checked some of the other threads were you explain how to change from a regular carb in to TPI..
So i have 2 main questions:
1. Is it easier or harder to change from a computer controlled carb into TPI than a regular carb???
2. If you are lucky on ebay or something how much in pricing for the whole kit..wireing harness, sensors, computer etc....????
Old May 14, 2007 | 09:08 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: Converting from Carb to TPI???
its a little bit easier converting from a computer controlled carb to TPI, but only because you already have a place for the O2 sensor, & there is a hole in the firewall for the harness to pass through. if your lucky, the hole won't need to be opened up for the TPI harness.
as far as price goes, it depends on what you find. about 4 years ago i saw a complete TPI setup for $400.00 which included fuel lines & sending unit with the fuel pump & all of the sensors. the wiring harness needed some work. it was off a 85 camaro so it probably needed a MAF too.
the 85 system had more then its share of problems with the MAF going out.
i would recommend going with a speed density system over a MAF system.
good hunting.
Old May 15, 2007 | 11:30 AM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
You can find good prices here and there. I picked up the manifold, plenumn, tubes, all sensors minus maf, for 150. You will have to find setup from an 87-92 car, due to the base being for the old style heads in the 85-86 cars. keep looking around and you will find a good deal.
cheers!!
Old May 15, 2007 | 01:39 PM
ok...thanks....Anyone know good sites or have a link to where you could buy a manual or something on TPI systems...think i need some reading and learn myself a little bit more about TPI before I'm beginning on that project..
Old May 15, 2007 | 03:22 PM
By the way...this may be a difficult question but hopefully here is someone that could have an answer...
Like i wrote on this thread I have a 305cid engine with a computer controlled carb...that means that I have this O2 sensor yes...
But what do I excacly need for my car to get the whole TPI setup??
Anyone that has this list for me??
I know the main things:
Intake
Harness
Sensors????
Please help me with this list....
theshackle
Mar 5, 2017 06:37 PM
69 Six Pack
Oct 5, 2015 07:51 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
