Corvette L98 alum. vs. Vortec
Old Sep 17, 2000 | 09:31 PM
markz28's Avatar
I know a guy who has a brand new set of the vette heads he has never used and can get a fair deal on. My question is should I wait till that new vortec intake for tpi becomes available? Aren't the intake ports on the vette heads only 163cc's? I guess there is also the weight savings of the alum. I have a LB9 with some mods but figured I'd swap in a cam, heads and headers at the same time. How hard would it be to find some of the vortec's to work on my 305? Thanks
Old Sep 20, 2000 | 05:46 PM
90Iroc's Avatar
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
Transmission: Borg Warner 5 speed
I hope that if you do go with the vette heads you truly are getting a good deal. One guy told me that he would sell me some vette heads for my 305 for $400. His were used at 30,000 miles and I found out I can by brand new ones for $422 at Paceparts.com
"Clear your mind, relax, and float downstream."
Old Sep 20, 2000 | 09:20 PM
DMan's Avatar
I think that is per head, not the pair
Old Sep 20, 2000 | 09:45 PM
steve8586iroc's Avatar
If the heads are off an L98 and are in good condition they would be the better deal. They have the right size combustion chambers and intake bolt pattern, you also can retain the factory egr system if it matters. As fare as flow numbers are conserned they flow a lot better than the stock head and are easy to port if you need more.
[This message has been edited by steve8586iroc (edited September 20, 2000).]
Old Sep 21, 2000 | 12:01 AM
Guest
Guest
Posts: n/a
"you also can retain the factory egr system if it matters"
No, you cant. The aluminum vette head has no provisions and cant be modified for any reasonable amount of money to retain the stock EGR setup.
How much? They are a pretty decent head for a stock head. Keep in mind Lingenfelter performs his magic on these heads for his 400ci engines, so how bad can they possibly be?
Old Sep 21, 2000 | 12:13 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The L98 heads also dont have the correct bolt pattern for 87-92 intakes. They have the 85-86 bolt pattern. But you'd want an aftermarket intake to take advantage of them, anyway.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
FormulasOnly
Jul 23, 2018 08:47 AM
the_hamturdler
Sep 30, 2015 12:50 PM
dusterbd
Sep 29, 2015 08:40 AM
monte87cortez
Sep 26, 2015 08:10 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
