TPI TO CARBURETOR SWAP QUESTIONS?
Car: 1987 Pontiac Trans Am GTA
Engine: 5.7L 350
Anyone swapped a carburetor into a TPI engine???
I swapped a new mini-ram intake with a fresh 350 and I can't seem to get it tuned right or a properly tuned chip thru TPIS. I ripped out all my emission components and A/C.
If I bypass my ECM with a carburetor, will I need a different transmission (Turbo 350 maybe)???
Will my stock digital dash and guages not work? Will I need all mechanical guages and new dash?
Any other electrical/computer issues with a carburetor set up??? Thanks
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
Re: TPI TO CARBURETOR SWAP QUESTIONS?
Do a search in the engine swap and electronics section. Here is a great engine wiring harness breakdown for you. The ecm dosent controll anything you will need for a carb motor.Attachment 139895
beachrodder
Aug 25, 2015 08:05 AM
Sanjay
Aug 12, 2015 03:41 PM
