Ign wire to Coil?
Old Oct 11, 2000 | 05:08 AM
NickS's Avatar
Ign wire to Coil?
I'm in the process of putting a battery kill switch into my '92 305 TPI Z28. Since its a road race car, its required to put it on the positive side of the battery, and it has to interrupt the ignition wire leading to the coil as well so it acts as a kill switch.
Since the switch is going to be located in the driver's compartment on the cross brace, idealy I'd like to splice into this wire somewhere inside the cabin as opposed to runnign a wire through the firewall.
I'm assuming that this wire runs from the PCM to the coil. If that's the case, does anyone know which wire on the PCM I need to splice into?
Thanks in advance...
- N
'92 Z28 CMC road race car
Old Oct 11, 2000 | 05:34 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
From my understanding, as far as NHRA goes, the switch needs to shutoff the car.
What I did was run the alternator charging wire (off the back terminal) all the way back to the A terminal of the switch.
I ran the wire from the B terminal to the front landing it on a remote starter soleniod. The power wire for the coil (12 gauge red factory wire with a fusible link) to the starter soleniod.
Therefore, when the switch is open, power from the battery and the alternator is disconnected from the coil, and everything else for that matter.
If you need more specifics, drop me an e-mail
Michael Graeber
My Garage
1)83 Z-28 T-Top: Full cage, 9" w/ lad.bars, Midwest Engine Tech 406sbc,Strip Dominator, Demon Carb, Phase VI Chevy Bowtie heads, .630" Crower roller set-up, 1 3/4 coated Hookers 3" true dual exhaust th400, fuel cell & still not running
2)89 Formula WS-6 305 TPI Auto For the road: minor motor, more suspension stuff. MODS
stalkier
Dec 6, 2015 11:25 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
L98GTA87
Aug 5, 2015 11:02 PM
