TPI manifold on L98 Alum. Heads...
Old Oct 12, 2000 | 12:36 AM
Germ's Avatar
Hi all-
I got a 87 305 (with TPI of course) and am lookin at gettin some of the L98 alum's for her. So i seem to remember there being a different angle for the manifold-- did the vette heads use the pre 86 mani interface? If so will all the aftermarket intakes work with it?
Also, whats involved in hooking up the EGR with these heads?
JEremy
Old Oct 12, 2000 | 04:03 AM
DMan's Avatar
Look down about 20-30 topics
Later,
Dennis K
88 Formula 350
Old Oct 12, 2000 | 04:37 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes, the L98/ZZ3/ZZ4 heads have the pre-87 intake bolt pattern, so you will need an aftermarket intake, a stock Corvette intake, or a stock 85-86 f-body intake. To run the EGR you will need to use an aftermarket or Corvette intake, and run the EGR like the Corvettes do. It takes the exhaust gas from the passenger exhaust manifold, or #8 header, and runs it over the valve cover to a port on the back of the intake manifold.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
