P/N wire help?
Old Jun 14, 2007 | 08:02 AM
SS ninja's Avatar
Engine: 5.7 vortec crate w/TPI
Transmission: 2004r
P/N wire help?
How does the Park/Neutral wire function?
Does the ECM expect to see current flowing through it when the car is in park or neutral, and this circuit is broken when the car is shifted into gear?
I'm trying to wire up my aftermarket harness to a B&M Megashifter, and it looks like I should splice the P/N wire into two ends, with either end going to one of the "prongs" on the switch on the shifter.
My car doesn't have a wire in the steering column to splice the P/N wire into as far as I can tell (I think it's a mechanical interlock, which just prevents the key from physically turning to the start position when the linkage isn't in park or neutral), so this seems like the only solution for me.
Is this correct?
Old Jun 14, 2007 | 08:41 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: P/N wire help?
The park/neutral wire to the ECM: ground it when in park or neutral, open when not. Stick shift cars just leave the wire open, so it is always in drive.
Please note that this wire to the ECM is not the neutral stop safety switch. There is another switch to disable the starter if the shifter is not in neutral or park.
RBob.
Old Jun 14, 2007 | 08:55 AM
SS ninja's Avatar
Transmission: 2004r
Re: P/N wire help?
So would my original idea be correct?
Is the wire properly grounded when the switch on the shifter completes the connection?
(I'm still learning wiring)
1992 Trans Am
May 10, 2023 07:19 PM
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
