blows smoke on startup, smells like fuel
Old Oct 19, 2000 | 01:07 PM
rich1034's Avatar
I need help with a problem. My 85 TA acts like it doesn't want to start. It will eventually, but when it does, it blows a big puff of white smoke out the tailpipes that smells like fuel. It doesn't do it every time, but when it does, it's pretty embarrasing. Usually does it when it hasn't been started in a few hours. It doesn't smoke while I'm driving.
Old Oct 19, 2000 | 11:42 PM
airdeano's Avatar
check for injector leak down. possible a leaky injector puddling fuel in the head port. hard to start an overly rich engine.
plugs will tell a tale if they are soot black then id look at that specific cylinder.
if not then id look for fuel pressure difficulties or weak spark...
airdeano
Old Oct 20, 2000 | 01:14 AM
IrocManiac's Avatar
Could just be the valve stem seals.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
Old Oct 20, 2000 | 11:05 AM
rich1034's Avatar
I thought that if was valve stem seals, it would happen when the car was parked for a while only, This thing will do it if I go in the 7-11 for 5 minutes, and not all the time. If it fires right up, then no smoke. I'll check the injectors today, and try that
bryan623
Mar 22, 2021 06:43 PM
chazman
Aug 28, 2018 03:25 PM
dyeager535
Aug 28, 2015 08:10 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
chazman
Aug 22, 2015 02:01 PM
