Andrew350
Old Nov 2, 2000 | 04:15 PM
Kyle F's Avatar
Andrew350
Goodluck on that project and hey I am going to be on a co-op in columbus over the winter and I am looking for some thirdgeners up there to hang out with maybe we can hit the town for a beer sometime or maybe we might run down to athens for some realy partying.
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank, bearings, rings, and magnafluxed rods. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,SVO 24# injectors,MSD 6A, Hypertech Power Coil, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, MSD Wires, removal of A/C hardware and a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace
http://geocities.com/SunsetStrip/Garage/9548/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/4 ton 350, one of those NASCAR F150's
Old Nov 2, 2000 | 05:32 PM
andrew350's Avatar
sounds like a plan.
where are you co-oping. come spring, and then fall, I will be co-op'ing in michigan for lear. i will be working on new 'vettes and caddy Evoqs.
Old Nov 3, 2000 | 11:01 AM
Kyle F's Avatar
I am working at Liebert. Its on the North side of Columbus just inside the 270 Outerbelt. I will bee there from December 4th to like March 17th or something. Unfortunatley I have decided not to work on cars as an engineer because of all those restrictions causing you to have to compromise in disign. I feel it will be more fun to do it as a hobby. (Also I couldn't afford to goto Kettering). Sounds like you have a sweet job lined up. Well I better go I have some Statics problems to finish up.
