ac question
Old Jun 28, 2007 | 07:28 PM
tourville's Avatar
Car: 1991 Camaro RS
Transmission: 700R4 Auto
Axle/Gears: 1 legger 2.xx(needs upgrade)
ac question
alright im getting ready to bolt my ac back to the car and convert it over with the kit. before i go buy the kit how can i pressure test the system to make sure it will hold? and also do i have to flush the system? if so how can i do that?
Old Jun 29, 2007 | 07:02 AM
uemf's Avatar
Car: '86 Firebird
Engine: '85 TPI on crate 350
Transmission: T-5 man
Re: ac question
Wrong forum... try positng in the A/C board... or I bet you'll be able to find all you need to by searching...(like you don't pressure test the system, you vacuum test A/C systems )
Old Jun 29, 2007 | 02:17 PM
tourville's Avatar
Car: 1991 Camaro RS
Re: ac question
i dont see an ac board anywhere and i have typed vacuume test a/c and pressure test a/c nothing i seem to type comes up with anything
Old Jun 29, 2007 | 08:23 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Re: ac question
Best bet is to just put the system back in, and change the orifice tube and accumalator if you want it to be ice cold. Then take it to a shop and have them recharge the system. Also, if you are converting a camaro from r12 to 134, you may need to install a high pressure cut out switch. Not sure as I haven't done one yet. I know most domestics need to have one installed.
Old Jun 29, 2007 | 09:04 PM
79malbiu's Avatar
Re: ac question
its the cooling section lots of info
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
