vac.leak from CSInjector w/ SLP runners
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
The CS injector hole is bigger on the SLP runners than the stock runners and I've tried bigger O rings,Permatex Gold,Black,
putting two O rings together w/o any luck.
Any suggestions?
THNX,
BD3
86 IROC mods:T.E.S.,Flowmaster muffler
T.P.I.S. airfoil,Dan Burk ported intake system,,March
pulleys,Accel 8.8wires,supercoil,ign.mod.
RAM AIR induction,gutted MAF,
B&M shift kit,3.73 rear gears,Accel afpr,Hypertech stage 2 chip,Random Tech.cat.,Lakewood lower control arms,Lakewood adj.panhard rod,mac subframe connectors
"The more I learn about women,the more
time & money I spend on my IROC"
Any suggestions?
THNX,
BD3
Thats strange. Try calling slp and explaining the situation. They should be able to provide you something to help out your situation. If you have to resolve it yourself, BE CAREFUL! Remember, this is fuel that your dealing with thats not too far from the headers. I dont think i need to say anything more. Whatever you do, do it right. My suggestion would be get a large washer and grind it down to the size that you need to fit the hole for the CS injector. Good luck
"Ever notice how imports sound like weedwackers"
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Had the same problem with my SLP runners. Closer examination showed a small burr inside that prevented the injector from seating properly. I hit it with my Mikita and all is well now.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
Jake
