Distributor - how much of a shaft in-play?
Old Jul 1, 2007 | 05:07 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
My TPI distributor has some in-play in the shaft, i.e. it moves up and down about a millimeter. Which translates to a degree or two of play in the distributor. Plus extra play in the distributor gears (another degree maybe).
Does anybody know what the in-play tolerance is? I couldn't find it anywhere.
Thx
Lou
Old Jul 1, 2007 | 09:28 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Distributor - how much of a shaft in-play?
a millimeter of vertical play is nothing
never come across one new or old that didnt have this paly in them they are not preloaded to have no play in them the gear is just roll-pinned in place not tight against the flat disc "bushing" at the bottom end of the housing inbetween it and the gear
you are worrying over nothing
if it had no play at then id be concerned it was binding up and something was bad wrong with it
good luck
Old Jul 2, 2007 | 10:20 AM
BigBadLou's Avatar
Engine: TPI
Alright, thank you.
I'm just trying to find the source of a possible misfire or whatever I should classify my problem as. So I thought I'd pull the distributor and check. Seems ok then.
Lou
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Damon
Sep 26, 2015 04:29 PM
6998poncho
Sep 25, 2015 02:56 PM
