Undrilled Vortec heads & TPI base manifold
Since I got tired of waiting for the SDPC Vortec base, I figured I should just go ahead and make my own
Basically I milled out a "step" in the mounting surface of a stock TPI base and welded in an extension to seal the raised runner ports on the Vortec head. Then I welded on a set of mounting pads and re-drilled the base for the 8-bolt mounting pattern. Next came the die grinder and after some serious hogging out of aluminum, had a nice port matched, raised runner, ported & polished TPI base manifold!
I'm still a couple of weeks away from firing up the motor but it sure looks like it's going to work just fine! If I can track down my brother's digital camera, I will post some pictures of the completed set up.
Overall, the project takes quite a bit of labor and access to some metalworking equipment but is definitely do-able!
'88 IROC that looks suspiciously like a Jeep.
It's like a 3rd-gen with the aerodynamics of a brick but that'll go about anywhere!
I'm still putting on pieces and parts, only having one day a week to work on it is a real pain. Sorry I haven't been able to load any pictures yet, hopefully soon. I expect that I won't be able to see the true performance gains for a while because I imagine there will be quite a few prom burning sessions before I have the tuning nailed down.
Updates to follow…
-Tim-
Updates to follow…
-Tim-
irocCJ, sounds like we have something in common! I just finished building a TPI 383 and put it into my 1979 CJ7 quadratrac with Turbo 400. Still working out the details, but boy oh boy is it FUN!!!!!
Dave Zelinka
Dave Zelinka
9192camaro
16
Feb 3, 2019 12:21 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
