Best Fuel pump for my application?
Old Nov 14, 2000 | 02:15 PM
theformula's Avatar
Check out my mods in my sig . The only mod to the engine itself is the ZZ9 (not in yet).
My fuel pump can no longer keep consistency. What's a good fuel pump to go with? Do I need an in tank fuel pump?
Should I get a pulsation free operating fuel pump?
Thanks guys!
'92 Formula
305 TPI 5speed
1LE package
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,Crane AFPR (42psi),MSD6AL,homemade cold air,K&Ns,3:73s,JET fan switch, Macewen white face gauges...ZZ9 cam (i still have to install it )
Old Nov 14, 2000 | 09:47 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
I have used the GM Syclone fuel pump for over a year and love it.... others here would probably prefer a Walbro, and that may come later for me, but right now I'm happy
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Cyclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Old Nov 14, 2000 | 10:14 PM
theformula's Avatar
Thanks for the response bro.
Hey, what is the pulsator? Crane Cams recommended replacing the pulsator then the fuel filter. Then if the problem doesnt stop try the fuel filter. If that doesnt work problem with fuel injection?
'92 Formula
305 TPI 5speed
1LE package
Old Nov 15, 2000 | 08:49 AM
1BADAZTA's Avatar
Is the Cyclone pump an intank design or inline? If you want to save yourself time down the road, you might want to check out an inline pump. Only because you don't want to be yanking out that gas tank more than you have to, its a pain in the *** if you don't have a lift to work on. I wish I did mine this way. You can probably get it from Summit, Jegs, or TPIS where I got my intank one. Good luck.
88'TA 305TPI 330HP, NATURALLY ASPIRATED, PASSES N.J. EMMISIONS. "I AM JUST THAT GOOD"
Old Nov 15, 2000 | 02:34 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
That flippin' pulsator..
When I did my pump, I re-used it. I wondered why the pump came with two clamps and a piece of rubber hose. I figured it was for cars that didn't use a pulsator.
Later on I find out that I shouldn't have re-used the pulsator, that it's inlet/outlet seals can wear out, and result in dropped fuel pressure. That's why the damn hose came with the kit- to get rid of the pulsator! Grrr...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
