Need help pritty please with a superam on top
Old Nov 9, 2000 | 06:04 AM
Wraith's Avatar
I finaly got the car running. The problem is at about 2000rpm I have surging. The car will rev fine if I hit the throttle to the flore but if I rev the car slowly it hits about 2000rpm and the tach bounces up and down a few hundred rpm. I think I found a vacume leak but I didn't have time to tear into it last night. Any help or ideas and I will be greatly thankfull. Thanks
1991 Trans Am GTA, Accel 300+ ignition, underdrive pulleys, AFPR, Accel SuperRam (ported out), Edelbrock lower intake (ported out), BBK 58mm TB, TFS 23* heads, SLP 1 3/4 headers, SLP 3" cat back (no cat), CompCam .495/.502 lift, Kenny Bell strut tower brace, lower frame brace, Jeg's SFC, Lakewood trailing arms and panhard rod
Pony's can run, but bird can fly
1987 Buick Turbo-T
1977 Chevy Blazer 4X4
Old Nov 13, 2000 | 04:40 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
I had that problem once. It was a faulty PROM. You might want to unplug the throttle position sensor and slowly run it through the rpms where you were having problems. If it runs clean then it is a bad TPS.
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
My IROC-Z
EFI Performance Club on Yahoo
Old Nov 13, 2000 | 11:11 AM
Wraith's Avatar
Thanks I'll give it a try tonight.
1987 Buick Turbo-T
Old Nov 14, 2000 | 03:38 PM
Wraith's Avatar
I dug into the motor yesterday and found that big vacum leak but the car still surges real bad at 2000rpm's. The car run o.k. but needs the idle adjusted (I'll do that tonight) and if you step into the gas it has a slight hesitation then it runs like a bat outta helll. Can anyone think of anything. Thanks
1987 Buick Turbo-T
Old Nov 15, 2000 | 11:26 AM
Blade's Avatar
How about a custom PROM ?!
Old Nov 16, 2000 | 11:03 AM
Wraith's Avatar
I aready have a custom prom. I guess I should that in my sig.
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Nick McCardle
Sep 10, 2015 08:36 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
rsrookie
Sep 5, 2015 07:08 PM
