MAP sensor, Code 32?
Car: 89 Irocz
Axle/Gears: 342
I may be wrong but I'll give it a shot. It could very well give you a bad reading. Heres the reason I say that I had all kinds of codes shooting out at me, MAF, EGR, TPS, and it turned out to be a busted vac line. After I replaced the line everything may was fine. I would check vac line if you haven't already cause changing the EGR is pain. I hope this was some help to you. Let us know how it turns out.
BumpaD82
Feb 26, 2016 02:57 PM
MikkoV
Sep 9, 2015 04:25 PM
