K&N FI system
Old Dec 6, 2000 | 01:41 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
K&N FI system
Will the K&N Fuel Injection air intake kit work on a 86 IROC w/305 TPI? I think it says it will work with the 350 TPI, but it doesn't say about the 305 TPI.
86' IROC-Z
5.0L TPI
Stock(for now)
Old Dec 6, 2000 | 02:49 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
K&N doesnt make a FIPK for the thirdgen cars, only the 4th gens. You might be able to make it work, but I dont know anyone who tried.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 8, 2000 | 12:31 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
Ok, my fault, I misread the info. It does only say 4th gen, but it says for FI and with MAF sensor, so it should theoretically work, right?? I wonder if anybody has ever done this. I just like the setup, I hate having the stock setup and I dunno if they make an easy to do, no brainer, for 305 TPI, cold air system. Or does somebody?
Old Dec 8, 2000 | 10:16 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
I doubt it would fit. Take a look at a picture of one and try to imagine it going in the same place on a 3rd gen. Instead of that, you can make your own FIPK. Cut out the bottom of the airbox underneath your filters and run some clothes dryer ducting down behind the foglights. Instant ram air. If you don't want to hack anything, you can at least remove the splash guards from underneath the filters...just make sure you don't run through any deep water! I killed a MAF that way.
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N
Hotrodboba400
Dec 10, 2019 07:07 PM
1992Z28!
Nov 19, 2015 07:33 AM
codeysabatini
Nov 10, 2015 04:07 PM
1990FirebirdGTA
Sep 22, 2015 07:26 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
