Do you really need to...
Old Dec 10, 2000 | 06:56 PM
nicksL98's Avatar
COmpletley TAKE OFF the runners when you go to swap injectors? Cant you just loosen them so you can get the upper off and go from there?
Old Dec 10, 2000 | 07:18 PM
Ron Mullins's Avatar
When I replaced my injectors I left the runners on. I had to seperate the fuel rail but it worked out ok and had no problems.
91 Formula WS6
Home Made Ram Air,K&N Air Filter,Air Foil,
Ported Plenum,Underdrive Crank Pulley, Crane AFPR, Edelbrock High Flow TPI Runers, Holley 19lb Fuel Injectors, SLP Headers, SLP Y Pipe & Complete SLP 3" Exhaust and Muffler, High Flow Cat, Mobil 1 Oil, Hotchkis STB, Spohn LCA's and Panhard Bar and other polyurethane goodies.
Http://www.geocities.com/91formula
Add your 91 F-Body to my 91 F-body's Links page, or be added to my F-Body Links Page.
Old Dec 11, 2000 | 01:39 AM
Mo's Avatar
Mo
I left the runners on as well, same deal
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
Old Dec 11, 2000 | 01:41 PM
rondubbs's Avatar
i tried to leave them on but i couldnt lift the fuel rail up high enough to get the injectors out,, it kept hitting the passenger side runner!!
Old Dec 14, 2000 | 11:52 AM
steve88iroc's Avatar
Car: 1988 IROC-Z
Transmission: WC T5
If you are going to loosen the runners anyways, what is the difference if you take them right off the car? It's only a couple of turns with the ratchet. Not a big job by any means.
Old Dec 14, 2000 | 01:07 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
My experience on my L98 was to remove the passenger side injectors first, then the driver's side injectors. By removing pass. side first, that'll give the driver side enough play area to get them out - no removal or loosening of the runners required. If your injectors have been in for awhile, I'd recommend stuffing the injector holes so that if the little "tang" on the lockring does break, it won't go down in there.
KAM
DuronClocker
Oct 25, 2004 03:06 PM
3rdGenSS
Aug 25, 2004 05:12 PM
Maverick H1L
Aug 10, 2004 12:34 PM
TheGreatJ
Jul 21, 2004 06:13 PM
Demon Z28
Pacific Northwest Region
32
Jun 25, 2001 08:05 PM
