Manifolds and Runners for TPI???
Old Dec 17, 2000 | 05:51 PM
IrocManiac's Avatar
Guys its getting closer to the time for me to start ordering the parts for my motor. I am going put a 350 in here in the next 6 months and in about 6-8 weeks I will start part ordering with every pay check. I have some questions regarding manifolds. I have heard and recommended Edelbrock because its supposed to be the best. How is TPIS compared with Edelbrock. Also Will an LT1 manifold work on L98 vette heads? What manifolds and runners would you guys recommend. I don't know if I can afford mini ram. I have heard that Edelbrock base plate and runners will flow enough for about 5700 rpm. Is this correct? Also are Edelbrock runners the best? Any recommendations would be greatly appreciated. Thanks!!!
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
Old Dec 17, 2000 | 06:43 PM
Lounge Lizard 6's Avatar
All of the TPI bases flow essentially the same. Edelbrock is the best bang for buck base out there. TPIS has their base cast by Edelbrock, adds some port work, and charges thru the nose for it. Accel's falls in between price-wise.
LT1 is reverse flow cooled and runs an Opti so it's intake it won't work on a L98 without major, major mods.
As far as runners go, people seem to like the AS&M ones the best.
Mike
'90 IROC-Z , 5-speed, ZZ4, G1 Trick Flows
Moderator SEThirdgen
Old Dec 18, 2000 | 10:21 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I bought the Edelbrck base and AS&M Runners. Runners are VERY NICE
Old Dec 18, 2000 | 08:50 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I've heard only good things about the edelbrock set-up too. They also say about a 15-18bhp increase. I'm not sure if that's on a stock or modified car. Does anyone know??
Rob
1987 IROC-Z Auto (LB9)
Black/grey with the stance of a streetfighter
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat.
Future mods:
K&Ns
RAM Air
New Underdrive pulleys-either March performance pulleys or Auto Specialties Performance
Air foil
Old Dec 18, 2000 | 09:12 PM
sven86berlinetta's Avatar
How much do the edelbrock intakes run? I've found the high flow runners (somewhere) but I haven't seen a price for the intake...
Luke
94 Saturn SL (1.9L)
86 Camaro Berlinetta (5.0L) *TPI 350 In Progress*
Berlinetta Board Mod @3rdgen.org
Non-Tech Mod @LG4 Performance Team
Old Dec 18, 2000 | 11:05 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
hey luke, i used to go to West Genesee back in 1990. Oh i called summit last nite, they want $365, but they are back order 16 of them and don't plan to have one till feb. On another note the stock base is suppose to be able to be opened up to flow like the "outta the box" EDELBROCK. Lastly BIG MOUTH by TPIS is like $500 so beware.
'89 SHAGGY IROC
L98 7r4, all free stuff,T.E.S.,HOOKER CAT BACK,KYB,ACCEL8.8,JET fan sw. etc.
so much to do , so little money
Old Dec 19, 2000 | 04:03 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
TPIS is $475. They charge you about $125 for the porting that they put into their manifold. I guess it depends on if you think their professional porter is worth $125 / hour !
Old Dec 19, 2000 | 05:05 PM
Really? I'm a junior at West Genny now. Small world -=)
Anyway, thanks for the info. I'll see what prices for getting the stock intake ported are.
Old Dec 20, 2000 | 12:23 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
GO for edelbrock base and AS&M siamesed Runners.
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Old Dec 20, 2000 | 09:08 AM
Scott C's Avatar
According to AS&M, their siamesed runners are designed only for heavily modded 350-383+ engines where upper rpm power is the goal. You will lose alot of low end power on a lesser moddified engine. AS&M suggests their large tube runners for all other apllications. The siamesed runners are also about $500!! The large tubes are $395.
Then you have to ask yourself if the AS&M large tube runners are worth $150 more than the Edelbrock runners. You can get the Edelbrock Hi-Flo "kit" which includes both the base and the runners for about $600. You'd pay $750 to get the Edelbrock base and AS&M runners.
Old Dec 20, 2000 | 11:16 AM
IrocStan's Avatar
If cost is your concern, buy the SLP runners and take the dividers out half way down. That will give you nearly the same port design as the AS&M's SS with half the cost.
That is what I did to mine. I'll be bolting them on during Christmas break along with a ported factory base and a CC cam.
I think they look better too
87 IROC 350, 3:42 Torsen, pocket ported 083 heads, complete Edelbrock exhaust, Most free mods, Most little mods, aluminum d/s. Edelbrock STB, SSM sfc's, boxed rear suspension pieces, urethane bushings everywhere.
Stock cam, chip, runners, base, and trans
13.94@103mph, 2.25 60'
In the works: ported SLP runners, ported base, Xtreme Cam, homemade suspension pieces, and 27x10 Hoosiers.
Goal: 12.999
Old Dec 20, 2000 | 02:15 PM
Dan87IROC-Z's Avatar
With all the money it costs to buy a new base, runners, TB and port your plenum, you could save a little more and just buy a Mini Ram and it would get you SOOOOO much more if it can be matched with the correct heads and cam. Just my 2 cents.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Next on the list: LT4 HOT Cam
Old Dec 21, 2000 | 07:48 AM
Aaron's 87's Avatar
I just want through this. I bought the Edelbrock manifoid and runners from carpartsonsale.com for $615 shipped. The runners measure 1.7" in most places. The base needs a lot of port work.
stalkier
Dec 6, 2015 11:25 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
