Pls. verify part no.
Old Jul 29, 2007 | 04:03 AM
snowmad's Avatar
Car: 89iroc-z 97-firebird
I need you to verify part no.
Is GM#15326386 the right part no. for both the coolant AND the intake air temp sensor?
(things is going from bad to worse)
//Lars
Old Jul 29, 2007 | 07:52 AM
deadtrend1's Avatar
Re: Pls. verify part no.
15326386 is the coolant temperature sensor for the ECM. The Intake Air Temp Sensor is part number all of its own. I'm trying to find the number to it but no luck right now....
Old Jul 29, 2007 | 12:01 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
//Lars
If it screws into the bottom of the plenum, they are the same.
Old Jul 30, 2007 | 02:44 AM
snowmad's Avatar
"15326386 is the coolant temperature sensor for the ECM"
the coolant censor i replaced did loock just a tiny bit different and had different ohm readings (most likely broken/corupt)
Yes it screws into the bottom of the plenum = then i got the right parts
//Lars
LT1Formula
20
Nov 14, 2015 12:02 AM
The_Phoenix
Sep 3, 2015 10:56 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
