how about a 170* thermostat?
Old Jan 5, 2001 | 03:10 PM
a_seiler604's Avatar
Car: 89 IROC-Z
Engine: 5.7 L V8
I'm thinking about putting a 170* thermostat in my IROC. I mainly want to extend the engine's life. (performance enhancements are always welcome, though) If I put the new stat in, what kind of changes am I looking at? Also, will I HAVE to adjust the cooling fans to turn on earlier, or will the engine be OK without cooling fan adjustments. I live in the Midwest where temps range from 5* in winter to 105* in summer.
1989 IROC-Z -- 5.7 L TPI -- TH-700R4 -- Hypertech Street Runner Chip -- AC Delco Ignition Wires -- Edelbrock TES w/ Dynomax Cat-Back -- K&N Filters -- AFPR (50 PSI)-- MAT Relocated -- All The Free Mods
Old Jan 5, 2001 | 05:27 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
It helps if you do the thermostat and fan switch mod at the same time, but you can do either one and come out just fine.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 5, 2001 | 07:01 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I USE to be a strong advocate of running cooler T-stats, but after seeing the effects of it (now that I am learn about the eprom), you are best to leave the T-stat.
Putting a lower temperature T-stat only "tricks" the ecm into giving more fuel, but it isn't necessarily the best thing to do. It really is a "fudge" on the ecm, when you REALLY need to burn a custom PROM.
From various articles I have read by various racing authorities (Smokey Yunick qualifies), they state that you want your engine as HOT AS POSSIBLE to get the maximum power out of your engine.
I understand the benefits of a cooler temperature on the TPI plenum, but the problem is the current GM prom anticipates a higher temperature CTS and coolant flowing through the TB. Putting a lower temperature T-stat (compounded with a TB bypass) makes the ecm run far too rich. You just waste gas and make your car possibly slower.
Trust me, until very recently, I was a strong advocate of a lower temperature T-stat, relocated MAT and TB Bypass. But I am now seeing that this is not a good thing.
PS: Just altering the fan(s) switch is not enough in the prom. You have to adjust the idle and the a few cold start tables if you TRULY want to run a lower T-stat. If not, the ecm thinks your engine is still cold, and you (again) just burn more gas.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Stryker412
Sep 20, 2015 06:59 PM
BWilcox
Sep 20, 2015 12:19 PM
