Any Dyno Numbers?
Old Jan 5, 2001 | 01:14 AM
91RamAir Formula's Avatar
Car: 91 Formula
Engine: 383 HSR
Transmission: 5th 700R4
Axle/Gears: 3.89
Any Dyno Numbers?
My 91 formula pulled 243rwhp 337tq at the rear wheel with mufflex 3.5" catback stock manifolds and stock dual cats. Also new TCI trans, no smog equipment, and 1.6 roller rockers. What kind of power has everyone elso made. Going to dyno this weekend with new AS&M SSrunners and ported plenum/base and AFPR I will post the results.
Old Jan 5, 2001 | 09:46 AM
KevinP92Z's Avatar
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
On my 92Z, when I still had the L98 in it, I had changed to the Edelbrock manifold & runners, along with Trickflow heads, SLP headers and the various things like a 52mm TB, MSD ignition ... This was with the stock bottom end of the block including the stock L98 cam. Feb 98 at the dyno it pulled 271 rwhp / 345rwtq. This was good for 13.4's @101 at HRP in summertime heat. Not too bad for stock cam and short block. I had intended to change the cam and re-test, but never got that far before wanting to step up to another level.
KevinP92Z
92 Z28 383 SLP cam,SLP headers,SLP 2ontheLeft,Trick Flow TW heads & pistons,Edelbrock base,Accel SuperRam,52mmTB,Scat Crank & forged ConnRods,MSD 6AL,SLP convertor,Baer 13/12" Track,Moser axles,Hotchkis,Genuine GM 3.42s,SLP HD Torsen,17x9" chrome SS rims
96T/A w/SLP Ram Air,SLP 2ontheLeft, Bilsteins, Baer, Hotchkis, Genuine GM, Torsen
76 4X4 Blazer 400TPI project
Old Jan 5, 2001 | 11:10 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
My convertible 350TPI with Edelbrocks intake base, runners and TES, Flowmaster cat back, Dynomax high flow cat, underdrive pulleys, K&N's W/chopped airboxes, SLP cam, stock heads, airfoil, ported plenum, Accel box & coil, and flowmatched injectors got me 260.1 RWHP.
Convertible, L98, Mini-ram, ZZ9 cam, Comp Cams 1.52/1.6 steel roller rockers, Trick Flow 23* heads, K&N's with chopped airboxes, March underdive pulleys, Edelbrock ceramic coated TES, Flowmaster cat-back exhaust, Dynomax high flow converter, MAC subframe connectors, Accel box & coil, 3.23 rear gears, white face gagues, and NOS!
When I get back from Kosovo I will be installing these on-order items!
Old Jan 5, 2001 | 12:23 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
double post
[This message has been edited by Kevin91Z (edited January 05, 2001).]
Kevin91Z's Avatar
Horsepower, Mods, and ET in the sig.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 5, 2001 | 09:30 PM
Greg90iroc's Avatar
i got 243 hp and 342 ftlbs at the rears. i could probly do better now but i don't want to spend the money. I graduate collage in a few months and then i will begin the mod fest and the purchase of many 3rd gens.
90 iroc l98
last season best corected 13.62 @102
mods
full exhaust, AFPR, pulley, jet stage 1 chip, billet servo, 52mm throttle body and a few other little things.
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
3.8TransAM
Sep 27, 2015 08:37 PM
