Stumbling Hesitation
Old Jul 29, 2007 | 11:01 PM
redcattaro's Avatar
Car: '84 Z28, '86 IROC
Engine: 305, 406
Transmission: T5, Super T10
Axle/Gears: 3.23, 4.10 Posi
now i know everyone is gonna say why don't you just use the search bar?? well, i did and didn't really find anything, all i found was things to check that i have already checked... so, it's a '86 305 TPI with a little bit of cam and the problem is that when i start it, it runs extremely rough and idles around 500 rpm in park and when you hit the throttle it bogs down even more and then it seems like the motor catches up and it revs up, but it also does this at all rpms when you snap the throttle, there is no check engine light, a few times it has stalled and not started and left me at a red light...i've checked almost everything: fuel pressure good, fuel pump and filter new, spark plugs wires cap and rotor new, tps sensor new and good voltage with no flat spots, maf sensor new, ecm new, air cleaners new, no vacuum leaks, timing set to 6*, throttle body clean, about 5000 miles on motor rebuild, once motor gets past hesitation it revs fast and pulls up to 5700 or so, i'm kinda out of ideas-could it be a weak coil? injectors? egr? air temp sensor? knock sensor? and also the cooling fan comes on as soon as i start the car and never goes off so maybe cts? idk, i don't wanna keep replacing things that are not the problem, i love tpi, but it has been giving it to me dry since i bought the car a year ago, any help would be appreciated, thanks
Old Jul 31, 2007 | 12:49 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Stumbling Hesitation
I would check the injectors. Check all the injectors with an ohm meter and see if any are significantly different than the others. If I recall correctly, each should be about 11-14 ohms. Sorry, but I don't know how to test them to see if they are flowing ok.
Hope this helps!
Old Jul 31, 2007 | 06:27 PM
redtail2624's Avatar
Car: 88 TA
Engine: 383 Converted LT1 intake
Transmission: TH350 3500 stall
Axle/Gears: 12 bolt 3.73's
I had the same problem and solved it by pulling the vac line off of the fuel pressure regulator to see gas coming out (bad regulator).
Old Nov 17, 2007 | 05:03 PM
IROCmenace's Avatar
Car: 1988 IROC
Transmission: 700R4 Silver Dart
Axle/Gears: 3.70 posi
Redcattaro, did you ever find a solution to the issue? I amy have a similar problem
Old Nov 17, 2007 | 05:23 PM
TRANSAMCRAZY's Avatar
Car: 87 T/A,92 T/A,
Engine: 406TPI,355TPI,
Transmission: 700R4 for all
Axle/Gears: 4.11,3.23,
I have an 87 GTA TPI 350 that did the same thing all it ended up being was the pressure regulator was worn out on the diaphram
Fanatic1074
Oct 3, 2022 05:57 AM
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
