305 tpi spark plugs
Old Jan 9, 2001 | 05:31 PM
dan92z28's Avatar
305 tpi spark plugs
I recently pulled my plugs on my still yet stock 305 block b4 i was gonna start my moddin. I noticed some oil deposits and compared it to the famous haynes spark plug guide and it said that i may need a vale job or replace my piston rings is this true?
HELP!!
Old Jan 9, 2001 | 08:40 PM
Lounge Lizard 6's Avatar
Depending on miles and condition of the engine maybe just your valve stem seals are tired.
Replacing them is very inexpensive, and it isn't too labor intense. Just requires a source of compressed air, a spring compressor and a few hours...
Mike
'90 IROC-Z , 5-speed, ZZ4, G1 Trick Flows
Moderator SEThirdgen
Old Jan 11, 2001 | 07:18 AM
Nitro Don's Avatar
If you dont have a compressor you can bring the cyl. your working on to TDC.and the valve will rest on the piston.This works for me.I dont like the idea of air holding the valve up.Its a bitch to drop a valve
Nitro Don
1990 Trans Am WS6
305TPI 700R4
ENGINE:
150hp NOS kit
March underdrive pulleys
Edelbrock headers(JetHot)
Mac off-road pipe
Flowmaster exaust
Jacobs ultra coil
K&N filter
Fulley ported base,
runners,& plenum
Crane AFPR
Hypertech airfoil
Crane 1.6 rockers
210/220 .533/.544 Cam
W/P Torquer heads
Edelbrock TPI Base
Edelbrock TI Runners
Edelbrock 52mm T.B.
TRANSMISSION:
Richmond 3.73's
Auburn posi
B&M Mega shifter
B&M Transpak
Vette servo
B&M 2400 converter
TCI Trans Rebuild
Nitto Drag radials
FUTURE MODS:
The 700R4 is DEAD!!
Neeed to rebuild AGAIN!!
BEST RUN:
12.48 @ 109.23 MPH
(with stock heads,cam,intake,and crappy Pep Boy's tires)
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Sanjay
Aug 12, 2015 03:41 PM
