'91 T/A TPI going into a '84 T/A need Tranny help!
Old Aug 4, 2007 | 02:00 AM
mecham84's Avatar
Car: '84 Trans am ‘86 Iroc
Engine: 305 auto, 305 auto,
Transmission: Automatic
I'm putting in a '91 TPI (speed density) into a '84 Trans am, I'm replacing everything including fuel lines, tank, pump, motor, and TPI unit/wiring. I have the mechanical speedo, and the 700r4 from the '91 is a electronic sender. Will that have any effect on the ECM if I put the original 700r4 to match the mechanical speedo? What would be the better way to go? Will the ECM have a hard time adjusting to the speed, with out the speed sensor? Any help will be greatly appreciated, Thanks Chris
Old Aug 4, 2007 | 06:22 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Re: '91 T/A TPI going into a '84 T/A need Tranny help!
You'll have to use one of those converters to switch it to an electronic signal. Shouldn't be difficult, just be sure to get one with a 2000 pulse per minute signal.
gta90
Sep 15, 2015 04:00 PM
Thornburg
Aug 25, 2015 01:46 AM
spaigo
Aug 21, 2015 07:46 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
