L-98 Valve Covers
L-98 Valve Covers
Hello, visiting from the Corvette forum. I am considering changing the valve covers on my car to aftermarket, but they do not have the drippers. Someone suggested to ask the f-body guys if the Camaro L-98's also have the drippers. My concern is lubricating the stock trunion of the rocker arm. I really didn't want to go to rollers at this point as I am considering a cam and want to wait before deciding on 1.5 or 1.6 rockers. Anyhow, I am getting away from my question. Does the Camaro L-98 valve cover also have the drippers like those in the Vette?
Bob T
1990 Roadster
Bob T
1990 Roadster
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
I bought a set of Comp Cams pro magnium roller rocker arms, TPIS said you have to remove the drip tabs so they'll fit. What excatly are the drip tabs?
They are little fingers in the top of the valve cover that direct the oil into the trunion of the stock rocker arm. They are not required for roller rockers, but I am trying to find out if all L-98's had them or if it was a Vette specific thing. Sounds like the f-body also has them.
On your rockers, are you going with new push rods and guide plates? I didn't think those rockers were self-aligning.
1990 Roadster
1990 Roadster
Engine: Miniram 383
Thanks, Yea the Camaros have em too. I have Comp Cams hardend pushrods for use with my Trick Flow 23* heads with guideplates.
Convertible, L98, Mini-ram, ZZ9 cam, Comp Cams 1.52/1.6 steel roller rockers, Trick Flow 23* heads, K&N's with chopped airboxes, March underdive pulleys, Edelbrock ceramic coated TES, Flowmaster cat-back exhaust, Dynomax high flow converter, MAC subframe connectors, Accel box & coil, 3.23 rear gears, white face gagues, and NOS!
When I get back from Kosovo I will be installing these on-order items!
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
