No more TBI, alll TPI (l98)!!
Old Aug 6, 2007 | 03:22 PM
The White Knight's Avatar
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
After spending the night
Different Angle :
Interior Shots SUPER clean!! Needs a vacuum, but I'll get around to it lol :
The Motor (Going over to detail it later today)Has K&N Filter and 1.6 Rockers :
I guess when GM swapped the 350 in it they changed the Emission label to 8) (doesnt look like anything under the sticker either) :
Exterior Shots :
New A/M Coil :
I also got a Chilton Manual, Haynes Manual and original GM Shop Manual its freakin HUGE lol, and some brochers and papers from Pontiacs 88 Line up, and a Front end bra.
Love the Bird, Code name is : White Knight
Old Aug 6, 2007 | 05:33 PM
t5camaro's Avatar
Car: 1991 Camaro
Engine: 355TPI
Re: No more TBI, alll TPI (l98)!!
Are you sure it has 1.6 rockers? My understanding is you need tall valve covers for 1.6. Thats the reason I havent installed mine. Thats just what i've read, so reply back I have to know so I can put mine on. Very nice car by the way. Love the TPI. check out mine. http://www.cardomain.com/ride/2662904
Old Aug 6, 2007 | 08:23 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I've had more sets of the narrow self aligning 1.6:1 rockers on stock TBI/TPI/LT1/Vortec engines than I can count.
Old Aug 6, 2007 | 11:28 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
hey fast, i've been thinking about doing this, the 1.6's i mean, i have a mostly stock exhaust but i've read that putting the longer rockers on just the exhaust side can be good for how chevy heads flow, for whats always going to be based on a LTR and l98 head combination, would reccomend this mod and which do you think is better, just on the exhaust side or on both?
Old Aug 7, 2007 | 01:37 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
U LUCKY GUY U
Old Aug 7, 2007 | 09:17 PM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
is that driver side valve cover on upside down or did the firebirds/ta's come like the the fill hole on camaro's is in the front. nice ride
I've run 1.6's s-a and non s-a w guid plat's under stock cover not a problem, do both
Old Aug 8, 2007 | 02:36 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
i want your t ram!! okay sorry i'll stop hijaking the thread, really a very nice formula! i'm jelous of your curb weight, my gta is down to 3500, thats only what, 300 lb's heavier then you stock, grrr...
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
TheExaminer
Aug 19, 2015 10:07 PM
Sanjay
Aug 12, 2015 03:41 PM
matthew911
Aug 12, 2015 09:38 AM
