where is the map sensor?
Old Jan 22, 2001 | 01:37 PM
camaroguy99's Avatar
I have a TPI setup from a 91 z28 and I was wondering where the map sensor is located. Is it that thing sticking out from the bottom of the plenum?
Old Jan 22, 2001 | 02:11 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
The MAP (manifold air pressure) sensor is on the passenger side of the plenum near the distributor and easily removed. I do this all the time to adjust my Fuel Prssure. It is held by a bolt on the side of the plenum and has the electrical connector and a vacuum line connected to it. Can't miss it.
The MAT (manifold air temperatur) sensor is on the underside of the plenum on the rear driver's side. It's a bitch to get at and basically requires loosening the plenum from the runners and tilting it up.
Personally, if my MAT was shot, I'd just install a relocated MAT and play with the fuel pressure/eprom tables.
[This message has been edited by Glenn91L98GTA (edited January 22, 2001).]
meeklay812
Oct 1, 2015 03:46 PM
Giocio
Oct 1, 2015 12:20 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
