TPI LT1 injector swap
Old Aug 12, 2007 | 04:25 PM
88 formula 350's Avatar
Hi I'm new here and I have a question. Does LT1 injectors work with a TPI for a 350. The reason I ask is because they are a littel shorter than the ones that were in the TPI when it was on a 305. Any help is appreciated thanks
Old Aug 12, 2007 | 06:01 PM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
Re: TPI LT1 injector swap
i thought they would as well, but no there to short and the ls1's are even shorter but can be used in an lt1/4
Old Aug 12, 2007 | 07:14 PM
Thanks I guess I'll have to get different ones then. Do 5.0 mustang injectores work or should I just try to find stock ones
Old Aug 13, 2007 | 01:05 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I have used '94 LT1 injectors in my TPI engine since 2001. I dont see them being shorter than TPI injectors, but GM has used several different injector styles over the years. The Ford SVO 19 lbs or 24lbs injectors will work too, and they're usually the best price.
Old Aug 13, 2007 | 10:32 AM
Thanks for the help I ordered the ford svo injectores should arrive soon.
Old Aug 13, 2007 | 11:18 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
good choice. But I just wanted to add I have 24# LT1's in my 305 TPI.
Old Aug 14, 2007 | 12:07 AM
socal's Avatar
are they cliped in and properly seated in the bore all the way to the bottom for the proper spray pattern to the valve area. i just ask since the set up i had wouldn't work
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
Sanjay
Aug 12, 2015 03:41 PM
