Would a big vaccuum leak make you lose power ?
Old Jan 26, 2001 | 03:13 PM
Blade's Avatar
Even since I put my TPI back toghether I have a vaccuum leak at the botton of one of the runners where it meets the baseblate. I think I put the gasket on backwards, since the gaskets were brand new and all the screws were torqued properly. The car feels good at part throtle, but WOT is slower then it usually is.. to the tune of about 5-6 tenths slower. This leak is pretty loud at idle, but the way I see it.. it just allows more air to enter that one cylinder. Why woudl THAT kill performance so much ? Also the car runs hotter... I'm planning to fix the leak tonite, but what do u guys think ? COuld thaT do it !?
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components, #24 SVO injectors.
Best ET 13.3@107 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
Old Jan 26, 2001 | 05:29 PM
ede's Avatar
ede
yeah fix it
ICON Motorsports
1st & 3rd
Old Jan 26, 2001 | 05:32 PM
Yelofvr's Avatar
At wide open throttle the amount of air coming in through the gasket leak will be minimal compared to the air coming down the runner, it should have VERY little effect. At idle or max vacuum situations, the effect will be more noticeable with that cylinder running lean because the air fuel ratio will be off. It should give you a rough idle. I would look somewhere else for you WOT loss of power.
midge54
Dec 27, 2019 04:14 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
TheExaminer
Aug 26, 2015 04:59 PM
cstrobel65
Aug 15, 2015 10:19 AM
sreZ28
Aug 14, 2015 07:48 PM
