Fuel Pump
Old Aug 16, 2007 | 01:20 PM
MP81's Avatar
Car: 2007 Cobalt LT
Engine: M62'd 2.2L L61
Transmission: 4T45E 4-speed Automatic
Axle/Gears: Stock
Fuel Pump
My fuel pump is really starting to go on my IROC (LB9), and I need to replace it.
Since I might as well not skimp on one (I'm planning on a 383 swap whenever I get the money), how does this BBK one look?
http://store.summitracing.com/partde...5&autoview=sku
Now, is there an access to the pump underneath the carpet in the hatch?
Thanks.
Old Aug 16, 2007 | 01:51 PM
Big Dave's Avatar
Car: 1992 RS Heritage
Transmission: TCI 700r4
Re: Fuel Pump
The pump looks good, not a "direct" replacement, but would definately work and accomodate your 383 down the road.
No access to pump from inside the car. Gotta drop the tank. Its pretty straightforward, but a lot of work... long job if you've never done it before.
Old Aug 16, 2007 | 02:01 PM
MP81's Avatar
Car: 2007 Cobalt LT
Axle/Gears: Stock
Re: Fuel Pump
No way to cut an access hole underneath the carpet? Or is that possible. I mean, it'd be "uncut" afterwards (aka, patched).
Old Aug 16, 2007 | 02:55 PM
The White Knight's Avatar
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
Re: Fuel Pump
I just did that to my formy, 30 min it was out, you have to cut the hard lines and attach with high psi hose. I used a dril and did a bunch of holes around in a square then cliped the spaces between the holes with wire cutters
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
