Injector size???????
How do I find out what the size is on my injectors?
When I bored the little 2.8 out I thought about changing the injectors but never did.Would I benefit from larger ones or would I be wasting money?
The injectors are the original fuel squirters.Besides having injector cleaner poured into the tank,they've never been cleaned.
[This message has been edited by Kevin S (edited February 10, 2001).]
You do not need larger injectors after engine boring, cam, or heads.. only when you increase the cubic inches a significant amount and/or raise the working engine speed a significant amount.
Examples:
Switching from a 305 to a 350 needs bigger injectors.
A built-up 350 pulling 1500 to 2000 RPMs over stock will probably need bigger injectors.
A built-up 350 that pulls within 500 RPM of stock would be fine with the same injectors.
I hope that clears this up some. Many people cause themselves a lot of grief by swapping injectors unnecessarily.
good luck
ODB
Examples:
good luck
ODB
92projectcamaro
Jan 18, 2016 08:00 AM
toronto formula
Nov 10, 2015 06:17 AM
