Are the left and right TPI runners the same????
Old Feb 11, 2001 | 08:13 PM
CamaroX84's Avatar
I have an '89 350 TPI motor, and one of my runners is damaged. Can I replace it with either a left or right runner set? They look the same, but I haven't tried bolting them up yet. Also, are the '85 305 and the '89 350 TPI intakes the exact same? Thanks.
Old Feb 11, 2001 | 08:36 PM
Guest
Guest
Posts: n/a
Nope, the runners are different. Near the top the small tube (EGR) is in a different spot.
The bases are different from 85 to 89, the center 4 bolts are different angles and 85 has a cold start injector. I think the plenum is the same.
Old Feb 11, 2001 | 10:06 PM
CamaroX84's Avatar
Are the 85 and 89 runners the same? Thanks.
Old Feb 11, 2001 | 11:24 PM
Guest
Guest
Posts: n/a
The right one is, the left one isnt. The difference is the cold start valve. That could always be plugged or capped off tho.
Vintageracer
Jan 10, 2020 05:33 PM
tazs2000
Jul 15, 2017 08:44 AM
stalkier
Dec 6, 2015 11:25 PM
mdtoren
Aug 23, 2015 12:52 PM
Sanjay
Aug 12, 2015 03:41 PM
