smog pump removal question
Car: '89 GTA
Axle/Gears: 3.45 9 Bolt
I have already read the tech article on removing the smog pump and rerouting the belt. I bought a Gatorback 96.75" belt the closest I could find to the 96.8" mentioned in the article, but it is too short. Does anybody know which belt I need? This is for a 5.7 TPI and All serpentine components are stock.
Car: 89 Trans-Am
Engine: 5.7 TPI
Re: smog pump removal question
How short? Does it Almost just make it or is it way too short? Sometimes using string can help. Just route it the same way as a belt, then allow 1/2" or so for tensoin pully. Hope this helps.
