Problem with my 85 TPI system
Old Aug 28, 2007 | 02:19 PM
handofheaven's Avatar
Car: 85 Trans Am (currently building)
Engine: gm 355
I'm in the process of putting a new 350 crate into my 85 trans am, which was bought with no engine. I have the original TPI and ECM from the 305, and have set it up on the 350. However, I am encountering a few problems.
1. The vacuum/coolant ports on the TPI. I am having trouble routing the hoses, as I don't have any good images/diagrams of the system. If anyone else has this system, could you send me a few pics from under your hood?
2. This is my more major problem. I can get the engine to fire and idle, but when the throttle opens, the engine dies. I suspect it may be a fuel/air ratio, but I'm not sure. Any suggestions?
Thanks, John
Old Aug 28, 2007 | 08:02 PM
canadian250's Avatar
Car: 1985 WS6 T/A
Engine: LB9 305 TPI
Axle/Gears: 9bolt 3:27
Re: Problem with my 85 TPI system
Do a search for a 305 to 350 swap. There are a few things that are different such as prom and knock sensor. I suspect your problem is there.
Old Aug 29, 2007 | 01:35 AM
Engine: gm 355
so i should swap the knock sensor,and injectors? going to 22 lb. injectors, the 350 knock sensors? Or could I modify the ECM for the 19 lb. injectors, and avoid needing a swap?
Old Aug 29, 2007 | 07:27 PM
Car: 1985 WS6 T/A
Engine: LB9 305 TPI
The 19lb. injectors are good to around 300hp I believe (don't quote me on that), and should work fine with a mild 350. The prom will have to be burnt accordingly of course.
Old Aug 30, 2007 | 01:16 AM
Engine: gm 355
canadian, since your car is the same model as mine, could you snap me a few pics from under your hood? I've been having some trouble with the diagrams for the coolant and vacuum TPI lines. I think some photos should answer my questions. Also, should I replace the prom, or can I just get a reprogram done? and if a replace, where should I go for it?
Old Aug 30, 2007 | 03:55 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Originally Posted by handofheaven
so i should swap the knock sensor,?
Both -85 corvette(350tpi) and -85 f-body(305tpi)uses same knock sensor and esc module.
Grant2k
Jul 10, 2018 04:01 PM
Fast355
Dec 2, 2016 06:33 PM
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
Sanjay
Aug 12, 2015 03:41 PM
