I am in the process of swapping a MAP TPI into a Nova. I am using an aftermarket harness that has VATS and EST Bypassed.
I am trying to get the thing to start before i put everything togeather. I tryed to fire it up today but i was not getting any fuel what so ever. At first i thought maybe my fuel pump was not supplying enough pressure to the rail, but i dont believe that is the case because the test light was not flashing when i jump the injector and spune the engine over.
Would not haveing all of the sensor hooked up do this? I figured it would at least run with the main one hooked up.
Map
TPS
Injectors
Distributor
those are what i have hooked up at the moment
Map
TPS
Injectors
Distributor
