TPI MODS. NEED HELP
Old Feb 17, 2001 | 02:30 PM
mustangs killer's Avatar
TPI MODS. NEED HELP
I have an 89' fomula 350. Right now every thing is stock exept 3.43 rear gears A chip and a shift kit. I want to gain 1/4 mile speed and all around performance. what mods. would you suggest and what would be the most bang for my buck. I do not want to bottle feed it. Thanks. I would appreciate all your suggestions.
Old Feb 17, 2001 | 02:45 PM
kevinc's Avatar
Car: 1982 Z28
Exhaust upgrades tend to yield great results, the factory manifolds and whatnot are really restrictive. Until you free up the exhaust, doing intake work like a better base won't accomplish much.
I'd consider a set of 1 5/8" headers like Hooker SuperComps (ceramic coated) or SLP stainless steel; a good aftermarket catalytic converter like Random Technologies, and a cat-back exhaust system & muffler like Mufflex. Plan for just over $1,000 in this mod. (headers $500, catalyst $300, cat-back $300).
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
Old Feb 17, 2001 | 02:48 PM
vortech305's Avatar
procharger kit w/12 punds of boost which include intercooler should help u run into 12's wiht the above modification that others have helped u with.
92' camaro
New 305 block TPI conversion, Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads accel cam,52mm throttle bodie, SLP runners,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods msd 8.5 mm wires hypertech coil and plug, Edelbrock TES headers, free flowing catalytic converter and a 3 ich force II flowmaster exhaust system.
Soon to come!!!
Procharger system 12lbs o boost.
Favorite quote: "where ever u go, there u are"
Old Feb 17, 2001 | 04:17 PM
The ODB's Avatar
Work on the exhaust first
Old Feb 17, 2001 | 06:22 PM
BadBowtie88's Avatar
One of the biggest bangs for your buck, is to buy a cam for it. You can get a good cam for about $250 and gain alot. Also look into runners for your intake, chips, pulleys, and headers.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
stalkier
Dec 6, 2015 11:25 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
