Hard start problem
Old Sep 2, 2007 | 08:54 PM
Dee555's Avatar
Car: 89 Iroc - 84 Trans Am -84 Corvette
Engine: 350 TunedPort
Transmission: 700R/T-5 World Class
Axle/Gears: Posi/Ausi/Disc/3.08
Hard start problem
Okay, I need some help here......I have a 1989 Iroc Z TPI with a hard start problem, car has been stored for 10 years and is only started and driven a very short distance (vehicle only has 57,000 miles). For the first 8 years all fluids etc have been tended to, however in the past 4-6 months its been really hard to start. The only way I can get it going is to use a battery charger with engine start. It cranks a bit then it starts. However once you shut it off and try to start it without the charger,,, N/G. It will keep cranking til the battery dies. Has anyone had this problem and if so how can it be corrected? Fuel pressure is 42 #s at the port also it has a new cap and rotor. Thanks Guys.....
Also have three other f Bodies does anyone know how swap from electronic carb to mechanical carb for an 84 Trans am........??????
Old Sep 2, 2007 | 10:09 PM
Abubaca's Avatar
Re: Hard start problem
I put high quality 4 gauge wire from :
Batt to Alt
Batt to engine/ground
Batt to chassis/ground
Engine to chassis
........I had a hard start issue too, replaced EVERYHTING! .....Less than $40 in wiring and connectors and now it fires immediately, even after weeks of no starts!
Old Sep 2, 2007 | 10:20 PM
Drac0nic's Avatar
After checking them and if they're ok, it may be best to yank the starter. Mine would be a PITA to start, it turned out that the brushes were eaten away, and the bolts were 1/8th inch gone because the commutator had eaten em.
Old Sep 2, 2007 | 10:57 PM
Dee555's Avatar
The starter turns when you crank it but..........
92camaroJoe
Jul 29, 2023 07:57 PM
db057
Aug 22, 2015 08:17 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
