Is the 9 bolt disc rear end better than the 10 bolt???
Old Feb 18, 2001 | 07:24 PM
njdaewoo's Avatar
From: Newark,NJ> Where street racing on I 78 RULES!
Hay, whats up everybody?
I have a question about the 9 bolt with limited slip, disc brakes factory gears which is on the car already vs. a 10 bolt with 373 gears,auburn limited slip and drum brakes. Can someone tell me which rear end is stronger? In my IROC/camaro which ran 12.50s at 115mph I had broke a few 10 bolt rear ends at the track so I started running street tires. thats why I get such a lousy 60ft 2.15 to 2.30's. Now with this 9 bolt I have no knoledge of the strength. Also wf i do switch to the 10 bolt will the disc brake master cylinder be okay with the drum brakes?
njdaewoo
406 sb
dart 200 heads(out the box)
144 B&M blower
373 gears
Edl headers
3in cat back Flowmaster exh.
270 comp cams
12.50s @ 115mph
on street tires
60ft time 2.30
www.njdaewoo@excite.com
New Project car
86TPI trans Am
All stock for now
Old Feb 18, 2001 | 08:05 PM
ede's Avatar
ede
9 bolt is stronger. you'll need the poportioning valve to make the brakes work with this swap
ICON Motorsports
1st & 3rd
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
