Fule Rail removel
Old Feb 23, 2001 | 06:40 PM
Z_Ghost's Avatar
Fule Rail removel
On a 92 TPI
I am pulling the intake off the car, and I am at the point were I can pull off the fuel rail . Now can I leave the injectors in the rail and pull them out as one unit ? I have everything unbolted but the injectors do not want to come out of the intake .
Help , and thanks.
Old Feb 23, 2001 | 08:43 PM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
They should come out with a litle persuasion. Gently pry them out of the intake and they should pop out. You may want to rotate them back and fourth while you are prying. The O rings are probably whats causing the injectors to stick...
89 Firebird Formula
WS6 package,ZZ4 Crate engine
SLP 58MM TB, Edelbrock TES Headers
Random Tech 3" cat, SLP 3" stainless exhaust
9 bolt rear, Hotchiss swing arms, Lakewood panhard rod
Corvette 2/4 servo, kevlar band, full poly rear.
Centerline 16x8 rims, B.F Goodrich drag radials
Old Feb 23, 2001 | 09:21 PM
Z_Ghost's Avatar
Thank's . I got them out .
gixxer92
May 18, 2017 11:20 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Briandrex
Oct 5, 2015 06:20 AM
bplessy
Sep 30, 2015 12:14 PM
dusterbd
Sep 29, 2015 08:40 AM
