inline or intank fuel pump?
Old Mar 4, 2001 | 05:29 AM
ausrs's Avatar
that about sums it all up ! converting from tbi to tpi i have to change pums so will an inline pump draw fuel through the stock one ?
thanks
Old Mar 4, 2001 | 09:17 AM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
I'm doing the same thing, you need an in-tank pump because the TBI pump you currently have is a much lower pressure, so by just putting a high pressure in-line with a low pressure in-tank will not work. Your TBI pump will be the restriction and the in-line pump will only pump what the TBI pump puts out.
Bottom line is drop the tank and put in a TPI fuel pump, and be done with it.
Old Mar 4, 2001 | 11:47 AM
The ODB's Avatar
inline
Old Mar 4, 2001 | 07:36 PM
ausrs's Avatar
<font face="Verdana, Arial" size="2">Originally posted by The ODB:
inline</font>
thanks i am going to disconnect the power to the in tank pump if i do the inline .
Old Mar 4, 2001 | 08:36 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
I would go with an intake pump. I am currently running an Accel inline pump. It works fine, but I get sick of listening to that sucker buzz all the time. If you do use an inline pump, you will want to power the intake pump also or you will prematurely wear out the new pump.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
