I need a cam for my 86 non roller 305tpi, any suggetions?
Old Mar 6, 2001 | 02:20 AM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
Hi there everyone,
Can any one give me advice on a cam for my 86ta with tpi? My current mods are 3.73s, Edl/tes headers, Flowmaster 3 inch exh single outlet,3 inch gutted cat,air temp sensor relocator kit, gutted maf. every thing else is a stock 190hp tpi motor. My goal is to try running 13.30s or better.
njdaewoo
Old Mar 6, 2001 | 02:46 AM
The ODB's Avatar
I suggest the cam in my signature.
*I do custom performance mods on Edlebrock Performer carburetors (dualplane intake mods in the works),
White 1986 Irocz, 305 with iron #416 heads,
383 with aluminum TFS heads,
Edlebrock Performer-RPM intake and Performer #1407 carburetor, +110hp shot of crack, 700R-4 tranny, Vigilante 2400 lockup converter, 3.25:1 Ford 9" rear, Mcreary Road-Stars, SLP-stainless 1.75" shortie headers & Y-pipe, single 3" Borla exhaust, Linginfelter-TPI camshaft part number 74216 pulls 17" vacuum solid. Cam specs 213/219 @.050 114-LSA, sometimes advertised at 216/219 @.050 112-LSA .462/.470 lift @1.5:1 ratio. Using Harland Sharp 1.65:1 roller rockers. MSD-6AL, billet distributor, multi-retard, blaster-3 coil, and RPM switch. SouthSide machine subframe connectors, SSM lift-bars, Moroso 4" underdrive crank pulley.
N/A runs 10.9 @124,
Crack-runs 10.3 @135
haven't run at track since Oct-99
Old Mar 6, 2001 | 08:50 AM
vortech305's Avatar
if u want to stay with a non roller cam and lifter theres this cam kit which inlcudes the cam,flat tappit lifter. Price 149.99 Summit sells it, its on their catalog, and they suggest u get a ADS chip all together 40 hp and they claim u will knock out almost a full second on the o-60 with their kit part # is SUM-G5000. Might i ad since u putting a cam get a new timing chain. If your going to roller cam, keep in mind u need roller lifter as well. ODB knows his stuff,so its up to u.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Mar 6, 2001 | 10:57 PM
The ODB's Avatar
No doubt man,
vizit miy homepayge!
http://www.geocities.com/trailerparkpage/
N/A runs 10.9 @124,
* vizit miy homepayge * http://www.geocities.com/trailerparkpage/
Old Mar 6, 2001 | 11:37 PM
R.O.B.'s Avatar
I've played with my Desktop Dyno2000, and with the headers and stock heads and TPI intake, the Crane Compucam2030 is the best choice.
One thing though, with everything you've got, those 3.73's are slowing you down! This engine can't rev to what the 3.73's need.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
Old Mar 7, 2001 | 12:10 AM
86Tra/maro's Avatar
Whats up peeps?
I dont understand why my 3.73s would slow me down? When I switched from the 2.77s to 3.73s the seat of the pants feeling was very strong! the car has to be faster!
njdaewoo
F.I. 57 Belair
Aug 23, 2021 01:09 AM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
