5.7L - 2.8L fuel pump, same?
Are the fuel pumps in the 2.8L MFI and the 5.7L TPI cars the same? I know the fuel pressure is the same, but of coarse fuel consumption would be different.
I also posted some wiring questions in the engine swap forum regarding different fuel pump wiring between a 86-89 that is causing me grief if anyone has more insight.
Thanks,
Mike
Thanks,
Mike
Car: 89 Firebird Formula
Engine: 305 Vortec, Single-plane, 4 barrel
Transmission: T5, soon 700R4
Axle/Gears: 88 10 Bolt, Disc, Auburn, 3.23
Re: 5.7L - 2.8L fuel pump, same?
I know that there were different fuel pumps used on different years of 60 degree V6 motors. One vehicle I had (Lbody) midway through the year (88) the pump changed.
Anyhow, I can't tell you but, when in doubt go to Partsamerica.com or autozone.com and crossreference numbers.
As for fuel flow of pumps used in 2.8 cars, I emptied a half-tank through the test port in the fuel rail in about 10-15 minutes I believe. But that is not at high pressure... I think they may be around 55lph ?? maybe not
-Dave
-Dave
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The fuel pumps are similar, but as you said the V8 TPI fuel pump puts out a lot more volume. The V6 pump is the same pressure, but less volume.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I also wouldn't trust a part number cross-reference from a parts store either. Often, a single common part is listed as a replacement for multiple stock parts. Why stock 2 pumps when 1 part number can serve both roles?
92camaroJoe
Aug 13, 2015 06:07 AM
