Where is the SES in a GTA
Old Mar 7, 2001 | 05:20 PM
88_TAOD's Avatar
I have the digital dash and I am pretty sure that my SES light doesn't work so does any one know where it is located so I can replace the bulb. I think it might be the upper left window. Or one of the circlular windows. Any help
1988 Pontiac Trans Am GTA
350 tpi, Fully Stock
BEST ET 15.4
Stereo
Alpine CDA-7864
Power Acoustik Apache Series 2200 watt amp
Two MTX Thunder 8000's in Thirdgen Box
Old Mar 8, 2001 | 05:32 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
You don't have the owner's manual?? That should tell you where it is.....
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Old Mar 8, 2001 | 10:06 AM
superz's Avatar
it should come on every time you start the car to signify that there is power to the ecm. if it does not come on when you start the car, you either have a dead ecm or there isn't power to it.
Old Mar 8, 2001 | 12:13 PM
custman87T/A's Avatar
I have the digi dash in my T/A also...to replace the bulbs you have to go from the passengers side to the drivers side and remove all plastic trim parts be carefull if you dont start on the passengers side and remove all of them there are some hidden screws that will break the plastic. Take the screws out that hold the gauge cluster in. Remove cluster. Hold a flashlight up to gauges to find the right one. Remove the bulb from the back of the cluster by turning the holder 90* and removing...be carefull not to damage the printed circuit. Also be carefull when putting the cluster back in that it plugs in properly. The system info is plugged in first before pressing the rest of the cluster back in and dont forget to line up the two holes on the bottom of the cluster with the pins in the dash. The only real pain in the a** is getting the cluster out from behind steering wheel and returning it back again I have seen a few of them that were destroyed cause prople dont know how to be patient. Oh yea having a tilt wheel really helps alot...you'll see what I mean
Old Mar 8, 2001 | 01:44 PM
rondubbs's Avatar
to answer your question,,, it is next to the e- brake light on the dash.
Falcon50
Aug 22, 2020 03:26 PM
sheachopper
Jul 31, 2019 11:27 AM
FormulasOnly
Jul 23, 2018 08:47 AM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
