How do I know a bad O2 sensor?
Old Sep 19, 2007 | 03:00 PM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
I was in the garage last night with the door open, trying to sort out my fast idle problem, and my eyes and lungs were burning because the car is running so fat.
I've replaced the IAC and TPS but the car still idles at 1500 and is running rich as ****.
Could a bad O2 sensor be the problem?
I messed with the O2 sensor when I put headers on the car a week ago when the problem started.
I'd expect lean if it were just a vacuum leak.
Thanks in advance.
Old Sep 19, 2007 | 06:08 PM
TPI383Camaro's Avatar
Car: 2008 Mazda B2300
Engine: 2.3l 4cyl
Transmission: 5-speed
Re: How do I know a bad O2 sensor?
i would check to make sure that the wire hasnt melted through on the headers.
if its not, replace the o2 anyway... they cost not very much at all
Old Sep 19, 2007 | 07:25 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
If you grounded the O2 wire to its base for even a second, it is bad.
Take the opportunity to upgrade to a 3 wire heated O2. It will play nice with your headers (Some headers don't let the o2 sensor heat up enough).
Old Sep 19, 2007 | 09:41 PM
Engine: tpi 305
Sounds like good advice. Do you think a bad O2 be responsible for my problems?
Old Sep 20, 2007 | 10:24 AM
Toehead's Avatar
Depends. The ECm will not use the o2 sensor input at all until it reaches about 160 degrees of coolant temperature. If yours is running reach even before it iw warm, i'd say the problem lies elsewhere.
Old Sep 21, 2007 | 08:22 AM
87 IROC NC's Avatar
Car: 1987 IROC-Z28
You should prob replace it anyway, they are like $6 and you should replace them every 6 months anyway. fyi, it is hell to remove it in my 87, don't know if GM put it in the same place in 89, just a warning.
Old Sep 21, 2007 | 10:40 AM
Engine: tpi 305
I will replace it. Where can I find instructions on istalling the heated job? I should have done this when I put the headers on last week.
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
L98GTA87
Oct 19, 2015 10:43 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
GTAman
Sep 21, 2015 09:57 AM
