A warning to all SLP T-ram owners...
Old Mar 12, 2001 | 10:08 PM
jimbo's Avatar
Car: 1991 Formula Firehawk (Clone)
Engine: 350 with Firehawk Package
The Ford SVO 24# injectors are not direct replacements for the factory units...I found this out the hard way. They are about .090" shorter, so the fuel rail will not seat properly on it. Not sure about the new Accel 24# units, but their tech rep said he thought they might be slightly shorter also. On a factory TPI setup, this is no big deal, because the fuel rail only attaches to the injectors, but on the T-ram, the fuel rail is part of the upper plenum, so the injector height is very critical. I ended up having to mill the plenum base to get everything to fit properly, and now it does, but if I ever go back to stock height injectors I'll have to remember to double up on the plenum base gaskets...
Old Mar 13, 2001 | 05:26 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I wish I had your problem, not having proper fitting injectors for my T-RAM SET UP!
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Mar 13, 2001 | 05:31 AM
jimbo's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Rob P:
</font>
Linson
Oct 24, 2025 02:00 PM
no green
Jan 9, 2016 09:22 PM
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
