Intake swap, TPI to LT1
Old Oct 4, 2007 | 11:20 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
Hey all, I just bought a 90 GTA with the 5.7 tpi. The car is mostly stock but I have started doing some upgrades. I am going to be doing some more work over the winter while the car is parked.
One thing I am thinking of doing is the LT1 intake swap. I can get ahold of a bare intake off of a 97 T/A. Is this a pretty simple intake swap or is there alot fabrication required? Will the stock tpi injectors work in the lt1 intake? Also do you have to tap the intake to run the thermostat and heater lines?
I was able to get some info when searching the forums. I know I will need to relocate the MAT sensor and the cts sensor will have to go into the thermostat housing. As for the thermostat housing can most auto parts stores get one or do they have to be custom made?
My car is equipped with speed density. Will it run with this intake or will I have to get a chip?
Finally, for now, is this swap worth the effort and time? I have heard the limiting factor for hp on the L98 is the intake.
Thanks,
Jay
Old Oct 4, 2007 | 11:37 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: Intake swap, TPI to LT1
LT1intake.com
If you don't have easy access to tools or don't have a good know-how, don't do it. It's time consuming, but it is worth it.
Old Oct 6, 2007 | 10:19 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
Sweet, thanks for the info. I might just order one of the prefabbed intakes he sells.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
masonta
Aug 31, 2015 10:14 PM
sreZ28
Aug 14, 2015 07:48 PM
Sanjay
Aug 12, 2015 03:41 PM
