no injector pulse bank 1
Old Oct 6, 2007 | 01:35 PM
89305formula's Avatar
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
last week i got a free set of 28lbs ls1 injectors the guy who gave them to me said he put a pro charger on his car and didnt need the injectors anymore and he said they all worked fine when he took them out, so i pulled out my 24lbs svo injectors and swapped the 28lbs in to ,it after fixing a few fuel leaks, i got it all back together and fire it up and im only running on 4 cylinders, 2-4-6-8, and i have no injector pulse to 1-3-5-7, i had a working ecm right next to me so i swapped it real quick thinking thinking maybe the injector drive in the ecm went out but that wasnt it, i check all the wiring i touched thinking i might have smashed a wire bolting the runners back to the plenum but that wanst it either, i dont have any wiring diagrams so im not sure which wires to start checking, if any one has any ideas or wiring diagrams post them for me, thanks
Old Oct 6, 2007 | 07:59 PM
TPI383Camaro's Avatar
Car: 2008 Mazda B2300
Engine: 2.3l 4cyl
Transmission: 5-speed
Re: no injector pulse bank 1
did you ohm the injectors? its possible that all the injectors on the one side are shot
Old Oct 6, 2007 | 08:19 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
check the INJ1 fuse in your fuse box
Old Oct 6, 2007 | 09:53 PM
Engine: 2.3l 4cyl
you know what youre right... cant believe i didnt think of that one.
Old Oct 7, 2007 | 09:39 AM
Car: 89 formula
Engine: 305tpi
Transmission: t-56
yea i did ohm the injectors they were all within .5 of each other, when i go by my shop later ill stop in and check the fuse, i didnt even think of that
86Firebird86
Dec 26, 2015 07:21 AM
92-Formula
Dec 12, 2015 10:34 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
