Stock Runners????
Old Mar 26, 2001 | 02:47 PM
CloudIROCZ28's Avatar
Stock Runners????
What's a good set of TPI Runners?, ones that have a way more increased air flow that would fit in the Stock Manifold and TPI setup.
Old Mar 26, 2001 | 03:20 PM
Dan87IROC-Z's Avatar
I have no experience with runners, but I have been told by a lot of people that the AS&M runners are the best. They are over $400 I think though. I am considering the Accel LTRs, they cost less and will match my Accel intake base.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old Mar 26, 2001 | 05:59 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its my opinion that the intake manifold is more of a restriction than the runners are. If you put larger runners on a smaller base, the incoming air will hit the smaller port on the base, causing reversions and killing power. Either change the intake manifold first, or do both at the same time.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 26, 2001 | 09:39 PM
DannysZ28's Avatar
The problem with the runners is the basic design. With the small diameter and constricted flow (curved nontheless), they suck. Straight flow would be the best.
1985 Camaro Z28
minor mods, wires, filters, etc., Accel SuperCoil/cap/rotor,
305 bored .030 over, new pistons, cam, lifters, timing kit, water pump, high-flow cat (3" out), Dynomax Afterburner muffler (2.5" out), O2 sensor, MAF sensor, 160W JVC head unit, Rockford Fosgate Punch 360 amp, 2 JL10W0 subs, custom box.
"You may laugh in the face of fear, but it'll be a nervous, unconvincing little laugh."
tazs2000
Jul 15, 2017 08:44 AM
stalkier
Dec 6, 2015 11:25 PM
Genopsyde
Oct 7, 2015 08:35 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
