O2 tuning from tech boards?
Old Oct 10, 2007 | 06:11 PM
jbpnumber03's Avatar
I just put 30 lb. injectors in my TPI. I saw this tech article on the main page. First off, can I do this with my TPI, and second off will it do me any good? Thanks.
Old Oct 10, 2007 | 06:18 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Re: O2 tuning from tech boards?
Yes you can do it, with the proper modifications to the injector constants in the tune. 30lb injectors will only do any good if you have a heavily modified engine that requires that much fuel.
Old Oct 10, 2007 | 06:21 PM
read here:
https://www.thirdgen.org/forums/tpi/...t=#post3467868
Old Oct 10, 2007 | 06:27 PM
battman's Avatar
Nice setup, 30lb are a bit overkill for that setup but it will work fine. I would look into getting it tuned, you are probably leaving some power on the table though. good job on bringing it all together.
Pac J
May 17, 2020 10:44 AM
sammy52401
Nov 11, 2015 07:20 PM
djmarch
Oct 2, 2015 10:41 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
