A different way to port?
Old Oct 11, 2007 | 11:13 PM
r_wells1's Avatar
Car: 89 IROC
Engine: vortec head/ZZ4 cam/TPIed 350+.040
Axle/Gears: 3:27
Has anyone cut out the dividing walls in the Manifold instead of the runners? Most porting of SLP like runners includes opening up the dividing walls between the runners where it bolts to the plenum. I was curious if instead someone tried to use stock runners and open up the walls in the manifold. This would allow access to the volume in 2 runners in stead of 1.
If some has, what kind of results did they get?
Old Oct 11, 2007 | 11:28 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: A different way to port?
its been done ive seen pictures of it you just gotta search i dont remember how well or not well that it worked.
Old Oct 11, 2007 | 11:29 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Yes it has been done. I believe MadMax was the first to post about it. I believe he had some success. You might want to do a lot of research on tuned runner lengths, runner taper and cross sectional area.
Old Oct 11, 2007 | 11:39 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
http://sethirdgen.org/TPIbase.htm
Old Oct 12, 2007 | 12:28 PM
88transam400tpi's Avatar
Car: 88transam/ 86 iroc-z/ 64 corvette
Engine: ta 400ci tpi/ iroc 327 / vette 327
Transmission: ta 5 speed/ iroc 700r4/ vette m-22
Axle/Gears: ta 3:42/ iroc 3:73/ vette 4:11
i had a 86 iroc about 3 years ago with a 383 i cut the intake runners down to 3.5 inches long and put slp runners on it but i did not cut the divider out of the runners. it ran great it was a big gain over the old edlebrock lower and slp runners
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
